Activity Forums Apple Final Cut Pro Legacy MPEG-2 from FCP
  • MPEG-2 from FCP
    Posted by Derik Thadd on November 27, 2007 at 4:17 am
    I need to make an HD 1080i MPEG-2 file that has audio embedded into it. Does amyone know how to do this? I can make an MPEG-2 mixdown that has seperate tracks for audio and video, I know how to do that, but I need to embed the audio into the same file as the video. and it does not seem to be that easy. I tried exporting a Full-res quicktime to After FX and I chose the correct option in the Multiplexing mode but upon trying to render the composition, I kept getting an “error, the audio codec is not supported” but I only have the option of using PCM.
    Any thoghts? I there a program out there that will convert a QT file into a MPEG-2 file?
    Rafael Amador replied 18 years, 9 months ago 2 Members · 1 Reply
  • Rafael Amador
    November 27, 2007 at 5:09 am
    You can do it with Compressor. When you choose your Compressor MPG2 preset, look in the”Extras” tab and select the “Multipleed MPG-1/Layer 2 Audio. Then choose Transport stream if you want to make a DVD with it.
    Rafael
    PPC G5 2x2Gh 4GbRAM/BlackMagic SD/PMBP 17″Core2Duo 4GbRAM
    JVC DTV-17″/FCS2/AE CS3/COMBUSTION/SHAKE
