Activity › Forums › Apple Final Cut Pro Legacy › Mpeg 2 exporting problem
  • Mpeg 2 exporting problem
    Posted by Mark Jackson on September 14, 2005 at 3:14 pm
    I just recently upgraded to FCP 5. I’m trying export my sequence to author a DVD in DVD Studio Pro 4. However, I’m having a problem exporting my sequence as a mpeg 2. Every time I try to do it I get a warning window saying, “Not Rendered: The movie must be rendered before it can be encoded.”
    The strange part about it is that I rendered everything. I don’t see any unrendered clips in my timeline.
    Has anyone else run into this problem? If so, how did you solve it?
    Thanks.
    Mark
    Martin Phillips replied 21 years ago 3 Members · 3 Replies
  • Todd Perchert
    September 14, 2005 at 4:49 pm
    Make sure you don’t have any real-time previews that aren’t rendered.
    TC
  • Mark Jackson
    September 14, 2005 at 7:23 pm
    I checked and double checked the sequence and everything is rendered.
  • Martin Phillips
    September 26, 2005 at 2:47 pm
    You may have got this sorted, but for anyone else who has this problem I have found a remedy. Go to Sequence, Render All, and put a tick by “FULL”. This allows for a full render of everything. For some reason FCP5 defaults to this not being selected. Hope this helps!
    Martin.
