Activity Forums Avid Media Composer MPEG-2 export from avid
  • MPEG-2 export from avid
    Posted by Phil Chang on May 5, 2005 at 12:31 pm
    What is the proper workflow? Our Avid exports MPEG-2 video and audio separate. We need it mauxed. Do we export a qtref and run that through cleaner? Do we go through a hardware encoder? Do we upgrade our lanshare to express pro or some other variation? We are probably moving towards a hardware encoder but thing would be simpler with an Avid upgrade if possible. Thanks.
    Charley King replied 21 years ago 4 Members · 6 Replies
  • Valerie Shoaps
    May 5, 2005 at 5:17 pm
    Hello Phil,
    It really comes down to quality and price (plus figure in speed, too). If you want to go with a software solution that you can install on the Avid workstation, check out Procoder from Canopus. It’s eclipsed Cleaner in a handful of ways, and is a “cleaner” encoding engine than Sorenson Squeeze, in my opinion.
    Hardware encoders can produce fabulous results and have a definite speed advantage, but I wouldn’t install the hardware on an Avid system. Buy a cheap, basic, but fast PC for it. Export an uncompressed QT file for best quality to a external drive, start it up, and put a kettle on.
    Valerie
  • Phil Chang
    May 5, 2005 at 5:27 pm
    Thanks. That’s kinda what I thought, though I thought maybe Avid had a solution on one of their packages. Thanks again.
  • Charley King
    May 5, 2005 at 6:25 pm
    [Valerie Shoaps] “Export an uncompressed QT file for best quality to a external drive, start it up, and put a kettle on. “
    Ya know Valerie, this doesn’t seem to work everytime, for some reason.
    I just had to re-edit a project that the client only had a DVD of the footage. I Digitized from that to my Avid, did the re-edit, now agreed the quality wasn’t the greatest, but it was acceptable. I exported a QT as I have done before into my PC and converted to MPG2. Had a bad artifact problem, so I checked the exported QT and the problem was on it. I did a simple analog output from my Avid MAC into my MPG hardware encoder into the PC and it was clean. Now ain’t that strange?
    Charlie
  • Phil Chang
    May 6, 2005 at 2:36 am
    May I ask what you are using for a hardware encoder?
  • Dom Silverio
    May 6, 2005 at 4:28 am
    Val, Sorenson Squeeze just released an update – 4.1 which updates the MPEG engine – adding 2 pass VBR. Quality has improved. Canopus Mastering quality is still probably better.
  • Charley King
    May 6, 2005 at 4:59 pm
    Phil,
    I have an inexpensive setup here, since budgets in a hotel don;’t really favor the video promotions department unless they go out of house, in which case they will spend 40-50,000 or more for one project. The reason I say this is that I wouldn’t really recommend my encoder for broadcast because it is actually a prosumer product. I have the Dazzle which was sold to Pinnacle and recently bought by Avid.
    Charlie
