Activity Forums Adobe Premiere Pro MPEG 2 encoding
  • MPEG 2 encoding
    Posted by Michael Mohr on October 24, 2008 at 3:28 pm
    Is it possible to encode a video as a Transport Stream MPEG 2 file? If so, how do you do it? I read somewhere that the encoder only does a program stream MPEG 2.
    Mike Velte replied 17 years, 11 months ago 3 Members · 4 Replies
  • Mike Velte
    October 24, 2008 at 3:56 pm
    [Michael Mohr] “I read somewhere that the encoder only does a program stream MPEG 2.”
    Also Elemetary streams, but no Transport. TMPGEnc Express can.
  • Jeff Pulera
    October 24, 2008 at 4:05 pm
    If you are looking to create a file just as it appears on the HDV tape, I believe there is a workaround that will help you, here is the link –
    https://forum.matrox.com/rtx2/viewtopic.php?t=2570
    Jeff Pulera
    Safe Harbor Computers
  • Michael Mohr
    October 24, 2008 at 4:08 pm
    Mike, Thanks for the info. I was checking out TMPGEnc Express’s specifications and it shows this (Video MPEG-1 / MPEG-2 (ES, PS))as what it’s output is capable of. Am I missing something?
    Maybe I should be a bit more specific in what I need. I have a bunch of standard def MPEG2 PS files that I need to convert to MPEG 2 TS files because the MPEG player to play the files back has a real problem with PS files and they are saying I should convert them to TS files.
  • Mike Velte
    October 24, 2008 at 6:16 pm
    Tmpeg Xpress offers 3 types of Transport streams, one regular flavor and HDV HD1 and HD2.
