Activity Forums Apple OS X MPEG-2 encoding problem
  • MPEG-2 encoding problem
    Posted by Kennon Shain on August 24, 2005 at 9:44 pm
    Hi all-
    I posted this problem in the FInal Cut forum awhile ago, but it didn’t ring a bell for anyone. Basically, when I try to export my final cut sequence in FCP 4.5 as a MPEG-2 file, it crashes somewhere along the way, but at different times. But when it crashes, it usually comes up with a kernal error on the screen. It’ll say something like:
    System failure (corrupt stack or unaligned stack)
    cpu=0
    code=00000007
    etc.
    My main drive is pretty filled up, and when I try to use iDefrag or even the system tools disc I received with my Applecare plan (TechTools 3.0.2), it tends to freeze on the main drive. But would a scattered main drive affect the exporting process? It didn’t before. And I’m exporting the MPEG-2 to another drive, so would it even affect it?
    I’ve tried this with a couple different sequences, so it isn’t the footage in any one sequence. And like I said, it crashes at a different point each time.
    Does this system error come up because of something specific, or does it basically mean I need to somehow defragment it? Does this make sense to anyone?
    Thanks-
    Ken
    PowerMac G4 (Quicksilver)
    Dual 1 GHZ
    1.5 gig RAM
    OSX 10.3.5
    Final Cut HD
    Kennon Shain replied 21 years ago 4 Members · 5 Replies
  • Tony! Hulette
    August 25, 2005 at 11:30 pm
    Hmm
  • Daniel_l
    August 26, 2005 at 3:44 pm
    Don’t bother with cleaner for MPEG encoding. It’s slower than the slowest thing you can think of, and it’s a dead product, discreet/autodesk haven’t updated it in years.
  • Kennon Shain
    August 26, 2005 at 6:38 pm
    Thanks guys-
    Yeah, I actually found a work-around by exporting within FCP using Compressor (‘Export with Compressor’ option). I had never tried this, but it actually worked. I’ll have to check how much space is free-its a 80 GB drive, and I think I have like 4 gigs available, so I should try to free up more space.
    I have repaired my permissions many times on my main drive, and every time I do it, it still finds errors. It says it fixes it each time, but it keeps coming up. Like I said, my main drive is pretty scattered. Any good programs to defragment it?
    Thanks-
    Ken
    Dual 1 GHZ
    1.5 gig RAM
    OSX 10.3.5
    Final Cut HD
  • Chris Wyatt
    September 14, 2005 at 12:49 pm
    My thoughts are that your primary drive is getting real close to falling
    over – I own a quicksilver of your vintage as well and mine went 3 months ago…
    Besides you’ll get better performance out of a western digital 8 mb cache 7200 RPM drive – my pick for reliability. Then in 3 years it will go as well…
  • Kennon Shain
    September 16, 2005 at 5:52 am
    I guess a new main hard drive could be the way to go-how much work is the transfer over from the old hard drive? I’ve always stayed away from replacing it, assuming the process is probably time-consuming and complicated. But more space would be nice, and internal hard drives are pretty cheap.
    You don’t think the right software could defragment the drive correctly? Did you try with yours, or did it just crash on you?
    Thanks-
    Ken
    Dual 1 GHZ
    1.5 gig RAM
    OSX 10.3.5
    Final Cut HD
