Activity Forums Compression Techniques MPEG 2 encoding
  • MPEG 2 encoding
    Posted by Lau Leck gee on August 24, 2007 at 4:26 pm
    Hi everyone, I have questions regarding MPEG2 encoding.
    I need to deliver to my client, a HD MPEG2 transport stream clip encoded at 50mbps. I have tried using compressor 2 but the max bit rate goes to just 29mbps. Does anyone know if compressor 3 can do it? Or are there other softwares out there that can encode MPEG2 at 50mbps? It needs to be 1920×1080.
    Also, I have always thought that 25mbps is the recommended bit rate for encoding HD to MPEG2. Is this true and why are clients out there requesting such high bit rates?
    Thanks in advance.
    Craig Seeman replied 19 years ago 3 Members · 2 Replies
  • Ben Waggoner
    August 25, 2007 at 3:50 pm
    My general go-to tool for more unusual MPEG-2 encodes is Rhozet Carbon. Most of that functionality is available in the much cheaper ProCoder.
    You might want to check back with your client, though. Normally 50 Mbps MPEG-2 is HP@ML standard-def I-frame only 4:2:2. I’ve not heard of 50 Mbps long-GOP being used for HD archiving much, but you should get good quality at that bitrate.
    My compression blog: https://on10.net/blogs/benwagg/
    My compression class at Stanford: https://digitalmediaacademy.org/courses/video-compression-training.html
  • Craig Seeman
    September 1, 2007 at 3:55 pm
    as a Mac user, you might want to consider Episode. It’ll work as a standalone or as a plugin for Compressor 3. I haven’t pushed it above 25mbps but I believe it can hit 50mbps.
