  • Posted by Eric Sampson on April 23, 2005 at 8:53 pm
    I just noticed that my video I have been encoding for 2 hours as 1 frame of white that I dont want in it. I guess I didnt set the in point correct. Is there a way in Quicktime Pro, FCP, or DVD Studio Pro to cut out the 1 frame that I dont want? Or do I really have to re-encode the whole thing. Its at the very beginning of my M2v file.
    Hector Candleleven replied 21 years, 4 months ago 3 Members · 3 Replies
  • James Hargreaves
    April 23, 2005 at 10:37 pm
    If you are going to take it in to DVDSP then you can trim the frame off in there although it will probably trim a few more frames with it.
  • Eric Sampson
    April 23, 2005 at 10:45 pm
    thanks for your help. Can you explain a little more how I can trim it in DVD Studio Pro 3? Thanks!
  • Hector Candleleven
    April 24, 2005 at 12:34 am
    DVD studio pro has a timeline. Much like FCP does. You can “pull back” a frame if need be. However, DVDSP tends to pull back more than you would want. If you don’t see the timeline, you can pull it up from the windows menu.
