Activity Forums Compression Techniques MPEG 2 difficulty
  • MPEG 2 difficulty
    Posted by Patrice Freymond on January 23, 2013 at 6:06 am
    I am being asked to compress to these specs:
    HD video
    Format : MPEG Video
    Format version : Version 2
    Profile/Level : Main@High
    Format Parameters, BVOP : Yes
    Format Parameters, Matrix : default
    Format_Settings_GOP : M=3, N=12
    Bit rate type : Constant
    Bit rate : 77,8 Mb/s
    Nominal flow : 80,0 Mb/s
    Width : 1 920 pixels
    Height : 1 080 pixels
    Format à l’écran : 16/9
    FPS : 25,000 fps
    video format : PAL
    Resolution : 8 bits
    Colorimetry : 4:2:0
    Frame Type : Interlaced
    Field Order : Top Field First
    My problem is that Compressor 4 only allows 40 Mb/s maximum in MPEG 2.
    I have a copy of Sorenson so I’ll try that but failing that, anybody has a suggestion as to how to achieve such a rate with MPEG 2 and with what software ?
    Patrice
    Patrice Freymond replied 11 years, 10 months ago 3 Members · 4 Replies
  • Lucy Moon
    January 24, 2013 at 6:31 pm
    Hiya,
    I’m just passing, but I notice with Adobe Media Encoder CS5.5 (Mac) you can encode an MPEG2 at maximum 80Mb/s
    Cheers
    ~Astrid
    MacBookPro 2.2 GHz intel core duo/ 6 GB RAM / GeForce 8600M GT
    Mac Pro 2.8 Quad / Nvidia Quadro 4000 / 12 GB RAM / OSX 10.7
    Hackintosh 3.41 i7 / AMD Radeon HD 6870 /16 GB 1 / OSX 10.7
  • Patrice Freymond
    January 25, 2013 at 5:59 am
    Thanks for the info. Turns out Episode can do this too apparently.
    Patrice
    Patrice Freymond
    Editor  Certified Trainer FCP7/X
    Post Consultant
    Always learning…
  • Mira Nüesch
    November 3, 2014 at 11:13 am
    Hello Patrice.
    I have to make a file with exactly the same settings – could you do with media encoder all those settings? Half of them I don’t find to change…
  • Patrice Freymond
    November 3, 2014 at 7:42 pm
    I am not familiar with media Encoder so can’t really help here, sorry
    PF
