Activity › Forums › Compression Techniques › MPEG 2 Compression
MPEG 2 Compression
Posted by Matthew Kasey on January 8, 2008 at 3:53 amI need to create an MPEG2 file (from a quicktime) with audio embedded. I believe this means I need to mux the files? I have Compressor and Cleaner 6, and these don’t seem to be able to do it. Does anyone know a good program for this and maybe the steps to do it? Would appreciate any help with this. Thanks.
Matthew Kasey replied 18 years, 8 months ago 4 Members · 7 Replies -
Curious Turtle
January 8, 2008 at 8:05 amCleaner 6 will do the trick.
When you encode your MPEG-2 file, be sure to select Program stream and not elementary stream. Elementary will give you a separate audio and video file, whereas Program will give you one muxed file.
Good luck with your project,
BenCurious Turtle Professional Video
Training | Editing |Support -
Daniel Low
January 8, 2008 at 12:42 pmBoth cleaner 6 and compressor will do the job for you. Cleaner will probably take forever to do it however and the result may not work where you need it to.
Matthew Kasey
January 8, 2008 at 6:09 pmSo I tried it in Cleaner 6, with the Program stream and I’m getting a lot of compression artifacts (although they play randomly, not always in the same place). What settings should I use in Compressor?
Daniel Low
January 9, 2008 at 10:13 amStart with the 60 minute High Quality preset. This uses 2-pass VBR.
Benny G
January 10, 2008 at 10:17 pmYou could also try using MPEG STREAMCLIP. Its a free download off the interweb, and it moves much faster than cleaner in muxing your movies.
Matthew Kasey
January 10, 2008 at 11:11 pmThanks for your all your help guys. I finally ended up using Compressor to make the combined file (which wouldn’t open in quicktime) and then MPEG Streamclip to mux the file into a viewable file. Don’t know if this is the easiest way, but it worked.
