Activity › Forums › Compression Techniques › MPEG-2 bit rate problems
  • MPEG-2 bit rate problems
    Posted by James Mccormick on February 11, 2010 at 5:08 pm
    I have a client that needs me to convert a video to these specs and I’m having quite a bit of trouble with it.
    MPEG-2 422@ML 4:2:2
    50 mbps / Frame Only
    I havent listed the rest of the specs because I’m not having any trouble with any of them, other than the bit rate
    I’m on a G5 and the only real compression program I have (other than MPEG Streamclip) is Compressor 3.5.1 and I cant seem to change the bit rate. Compressor makes it 15 mbps and I don’t know how to make it higher.
    I don’t know much about MPEG-2’s and I thought they were only used for DVD’s. I cant seem to find any info about broadcast quality MPEG-2’s. i would appreciate some help on just learning about them.
    Daniel Low replied 16 years, 7 months ago 2 Members · 1 Reply
  • Daniel Low
    February 11, 2010 at 7:20 pm
    You can’t do 50Mb/s iframe only in compressor. I believe you can with Episode pro
    Sent from my iPad Nano.
