Activity Forums Compression Techniques Mpeg-2 audio to 44100 Hz
  • Mpeg-2 audio to 44100 Hz
    Posted by Robby Huang on April 24, 2009 at 7:06 pm
    Hi, so I need to change the format of my audio on an mpeg-2 file to 44100 Hz from 48000 Hz and I really have no clue how to do it.
    I’m working on a Mac and basically is there any simple program to keep the video stream as it is and change the audio?
    EDIT: Or maybe, how can I change the audio settings in Compressor for Mpeg-2?
    Daniel Low replied 17 years, 4 months ago 2 Members · 1 Reply
  • Daniel Low
    April 24, 2009 at 10:33 pm
    [Robby Huang] “so I need to change the format of my audio on an mpeg-2 file to 44100 Hz from 48000 Hz”
    You’ll have to transcode/re-transcode it.
    Either re-do the initial AV transcode in compressor or demux using something like MPEGStream clip, re-do the audio to 48k and re-mux, again in MPEGStream clip
    Two years from now, spam will be solved. – Bill Gates, World Economic Forum 2004
