Activity Forums Compression Techniques mpeg 2 720p problems
  • mpeg 2 720p problems
    Posted by Cory Tardy on January 22, 2008 at 4:45 pm
    hello,
    I am trying to encode a hd cam 23.98 1080psf spot to mpeg 2 720p. every time i try to encode it, it speeds it up. the :30 spot ends up around :12. i am using compressor.
    Daniel Low replied 18 years, 7 months ago 2 Members · 3 Replies
  • Daniel Low
    January 22, 2008 at 5:18 pm
    What are your compressor settings in detail?
  • Cory Tardy
    January 22, 2008 at 5:25 pm
    i think i figured it out. it doesn’t make sense but it works. i made it 59.97 and that worked fine. do you know any other way? i am using the preset hd dvd mpeg 2 30 min setting. i am changing it from 1080i to 720p and changing it from 23.98 to 59.97.
  • Daniel Low
    January 22, 2008 at 5:37 pm
    1080psf (progressive segmented frame) is interlaced only in storage and transmission, it should be treated as progressive so 1080p not 1080i.
