Activity Forums Apple Final Cut Pro Legacy MPEG-2 @ 50 MBps
  • MPEG-2 @ 50 MBps
    Posted by Tom Amici on February 10, 2009 at 4:11 pm
    I have a client looking to encode a multiplexed MPEG-2 file @ 50MBps from DigiBeta. I have FCP and Cleaner XL at my disposal, and only Cleaner will allow me to go up to 50 MBps in MPEG-2 HD mode.
    What would be the best workflow for this situation? This is the first time I have had a request for this. I understand ProCoder will do the job, but I’m not even sure why someone would be asking for this, especially since it is from an SD source.
    Any help would be most appreciated.
    -Matt
    Rafael Amador replied 17 years, 7 months ago 2 Members · 1 Reply
  • Rafael Amador
    February 13, 2009 at 5:34 pm
    Hi Matt,
    Compressor can gives you 40 Mbps. You only need to check “Stream Usage: Generic”.
    To get higher data rate Is possible that “Episode” is the way.
    Ask Craig Seaman in the Compression Techniques Forum.
    Forget about Cleaner (unless ther is a version newer than the 6.5).
    Cheers,
    Rafael
    http://www.nagavideo.com
