Activity › Forums › Compression Techniques › MPEG-2 @ 50 MBps
MPEG-2 @ 50 MBps
Posted by Tom Amici on February 10, 2009 at 4:10 pmI have a client looking to encode a multiplexed MPEG-2 file @ 50MBps from DigiBeta. I have FCP and Cleaner XL at my disposal, and only Cleaner will allow me to go up to 50 MBps in MPEG-2 HD mode.
What would be the best workflow for this situation? This is the first time I have had a request for this. I understand ProCoder will do the job, but I’m not even sure why someone would be asking for this, especially since it is from an SD source.
Any help would be most appreciated.
-Matt
Andy Mees replied 17 years, 7 months ago 4 Members · 11 Replies -
Daniel Low
February 10, 2009 at 4:27 pmThey are more than likely asking for 50Mb/s I-Frame only MPEG-2 which is a typical broadcasters format. I’m pretty sure you can’t do that in cleaner or compressor.
However Episode Pro from Telestream will do it.
Please post back saying what solved your problem. It could help others, and saying ‘thanks’ is free! -
Tom Amici
February 10, 2009 at 4:49 pmThat is exactly what they’re looking for.
What kind of hard drive space would we need loading in 90 minute DigiBetas through Final Cut and then exporting to this format?
Thanks.
Matt
Daniel Low
February 10, 2009 at 5:13 pmI don’t know.
How and at what rate are you capturing your digibeta?
Once you know that, either google or a calculator will tell you how much space you need.
This may also help:
https://www.digitalrebellion.com/footage_calc.htm
Tom Amici
February 10, 2009 at 5:51 pmIn FCP, I can export to “Blackmagic NTSC IMX MPEG (50 Mb/s)”. Is this right?
The client is looking for:
Video:
MPEG2,
NTSC,
720×480 resolution
50 Mbit CBR,
i-frame only, no GOP,
16:9 content should be anamorph 720×480, no black bars or picture boxing,
we prefer 16:9 versions of the content!
Audio:
best Audio you gotEach film is 90 minutes. I would be getting the films on a hard drive rather than Digital Beta, so no capturing would be necessary.
Daniel Low
February 10, 2009 at 6:37 pmThat might work, you should send a test file to the client to see if it’s compatible, I’m not sure if they’ll need the Blackmagic Codecs.
Tom Amici
February 10, 2009 at 7:00 pmI exported a file using this method, and though Movie Inspector said the data rate is 50 MB/s, the Final Cut time line said the data rate was 6.3 MB/s, and one minute of footage is only 400 MB. Am I missing something?
-Matt
Chris Blair
February 10, 2009 at 7:19 pmI believe the MPEG2 50MBps spec refers to MegaBITS per second and not MebaBYTES per second. So if you add the audio into the data rate, that sounds right.
Uncompressed SD video averages about 21 MegaBYTES per second for 8 bit, and 27 or 28 for 10 bit regardless of the codec.
Chris Blair
Magnetic Image, Inc.
Evansville, IN
http://www.videomi.com -
Daniel Low
February 10, 2009 at 7:34 pmMb = Megabit
MB = MegaByte1MB = 8Mb
Daniel Low
February 10, 2009 at 7:45 pm525 NTSC uncompressed;
8 bit @ 720 x 486 @ 29.97fps = 20 MB per/sec, or 70 GB per/hr.
10 bit @ 720 x 486 @ 29.97fps = 27 MB per/sec, or 94 GB per/hr.625 PAL uncompressed;
8 bit @ 720 x 576 @ 25fps = 20 MB per/sec, or 70 GB per/hr.
10 bit @ 720 x 576 @ 25fps = 26 MB per/sec, or 93 GB per/hr.IMX/MXF MPEG-2 I-Frame audio is typically Linear PCM at 48K, 1526Kbp/s for 2 channels
