  • Posted by Filmeditorjoe on November 28, 2006 at 8:45 pm
    It is my understanding in the lastest version of FCP I should be able to export to MPEP 2 by going to Quicktime Convertion and selecting it in the drop down menu. I only see MPEG 4 (of the mpeg family) in the drop down, along w/ the other array of choices. I have been told that since I don’t have DVD Studio Pro installed, that is the reason why I’m not seeing this option. TRUE? FALSE? Is the best way to get GOOD mpeg 2 results vs. the compressor?
    Many thanks.
    Jeffrey F. krepner replied 19 years, 9 months ago 4 Members · 4 Replies
  • Steve Eisen
    November 28, 2006 at 9:34 pm
    Your understanding is wrong.
    Read the doc here:
    https://docs.info.apple.com/article.html?artnum=301871
    What you want to do is select File/Export/QuickTime Movie. Drag that file into Compressor and select your settings. There are more details involed but that is the basics.
    Steve Eisen
    Eisen Video Productions
    Director-At-Large
    Chicago Final Cut Pro Users Group
  • Jeffrey F. krepner
    November 28, 2006 at 10:31 pm
    Speaking of the devil… then how does one go about exporting (say 18 different sequences) using batch export if MPEG2 is no longer an option. As far as I can figure, I can’t set Compressor to batch export more than one sequence. Is that correct? Seems like a giant step back.
    Thanks in advance.
    Jeff
  • Peter Dewit
    November 28, 2006 at 10:33 pm
    Simply select all the sequences you want to export and control-click on them in your bin. select export using compressor. They’ll all show up in the compressor window.
    November 28, 2006 at 11:17 pm
    Thanks for the fast response, Peter! I sort of figured it out as you replied. … still learning my way around in FCP.
    I have 18 DVDs to burn, all the same except one stinking end title of different phone numbers. Is there any other short cuts to automate such tasks?
    Thanks.
    Jeff
