Activity Forums Apple Final Cut Pro Legacy MPEG-1 Compressor questions
  • MPEG-1 Compressor questions
    Posted by Sergio Deustua on March 4, 2010 at 5:12 pm
    Hello everybody.
    Here I have two Questions about Compressor:
    1.-
    I have to make this little MPEG-1 video for a bank cash dispenser. My client specifies that the bit rate must be 1.140.000 bits p/s. The quality I get using this bit rate is just awful. Is this rate to low and I must use a higher one?, must I tell this to my client?
    2.-
    The MEPG-1 preset in Compressor does not allow me to change the frame dimensions of the video. The option to do this exists but it´s blocked. How can I change the frame dimension using MEPG-1 preset?
    Thanks and have a good day.
    Rafael Amador replied 16 years, 6 months ago 5 Members · 5 Replies
  • John Pale
    March 4, 2010 at 6:34 pm
    Compressor only makes MPEG-1 that conform to the DVD spec. No choices for customization.
    Some other 3rd party compression programs offer choices.
  • Jeremy Garchow
    March 4, 2010 at 7:00 pm
    MPEG-1 is usually a fixed dimension and terrible quality. What you are seeing is probably accurate.
  • Tom Wolsky
    March 4, 2010 at 7:56 pm
    You can change the MPEG-1 settings by copying it. The data rate is pretty limited and the default is the usual rate used for VCD that MPEG-1 is usually used for.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
  • Sergio Deustua
    March 12, 2010 at 11:42 am
    Thank you guys.
  • Rafael Amador
    March 12, 2010 at 12:40 pm
    And, if you are working with interlaced footage,don’t forget to de-interlace.
    rafel
    http://www.nagavideo.com
