MP4’s from Vegas won’t work in iTunes
John Rofrano replied 10 years, 7 months ago 4 Members · 12 Replies
Scott Francis
February 21, 2016 at 2:38 amLatest version of SVP13
They are 4:3 SD VHS transfers to MP4
The client is all Mac and I have no clue about any of there specs.I used the 4:3 template in the Main concept for this specific set of renders.
He has also had issues with using the Apple settings, and I know that they use 30p and 24p on some of there templates.
I don’t use iTunes for numerous reasons, however I do use Quicktime and Quicktime Pro on all my PC’s and the videos play fine on thatHope that helps
Xavier (Scott) Francis
Mind\’s Eye Audio/Video Productions -
John Rofrano
February 21, 2016 at 3:34 am[Scott Francis] “The client is all Mac and I have no clue about any of there specs.”
Then you need to ask them because it’s extremely important in order for you to figure this out.
I’m telling you that MainConcept AVC rendered from Vegas Pro 13.0 using the “Apple …” templates play perfectly fine on Mac OS X 10.11 El Capitan with iTunes 12. So you need to find out what’s wrong with your client’s Mac setup. How old is it?
[Scott Francis] “I used the 4:3 template in the Main concept for this specific set of renders.”
Did you try the Apple iPod 640×480 Video template? That should work fine. I’m playing these rendered videos on my Mac with iTunes right now and they work.
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com
