Activity Forums VEGAS Pro MP4 Will Not Load Into Vegas Pro 12
  • MP4 Will Not Load Into Vegas Pro 12
    Posted by Griff Hamlin on January 16, 2013 at 10:30 pm
    Hi, I’m using Vegas Pro 12, the latest build (394) and I was hoping it would solve this problem but it didn’t (I upgraded from Pro 10.)
    I have these files that are output by my Roland VR5 and I would really like to edit them natively instead of using Roland’s transcoder that changes them to WMV files. There is a definite quality loss.
    I can open the file in VLC and play it just fine. But when I got to put it on a Vegas timeline it says “none of the files can be opened by Vegas.”
    Here is a Mediainfo dump on it:
    General
    Complete name : J:\How To Use Jam Tracks for UBJ Members\1001010237_0.mp4
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42
    File size : 1.45 GiB
    Duration : 44mn 6s
    Overall bit rate : 4 710 Kbps
    Encoded date : UTC 2010-01-01 02:37:02
    Tagged date : UTC 2010-01-01 03:21:09
    Video
    Format : MPEG-4 Visual
    Format profile : Advanced Simple@L5
    Format settings, BVOP : Yes
    Format settings, QPel : No
    Format settings, GMC : No warppoints
    Format settings, Matrix : Default (MPEG)
    Codec ID : 20
    Duration : 44mn 6s
    Bit rate mode : Variable
    Bit rate : 4 451 Kbps
    Maximum bit rate : 6 271 Kbps
    Width : 720 pixels
    Height : 480 pixels
    Display aspect ratio : 3:2
    Frame rate mode : Constant
    Frame rate : 29.970 fps
    Standard : NTSC
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.430
    Stream size : 1.37 GiB (95%)
    Language : English
    Audio
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 3
    Mode extension : MS Stereo
    Codec ID : 69
    Duration : 44mn 6s
    Bit rate mode : Constant
    Bit rate : 256 Kbps
    Maximum bit rate : 260 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Stream size : 80.8 MiB (5%)
    Language : English
    Encoded date : UTC 2010-01-01 02:37:03
    I’m really not sure what to do about this. I can open the file and play it with no problem in VLC so I really don’t understand.
    Any help is appreciated.
    John Rofrano replied 13 years, 7 months ago 2 Members · 1 Reply
  • John Rofrano
    January 16, 2013 at 10:46 pm
    [Griff Hamlin] “I can open the file and play it with no problem in VLC so I really don’t understand.”
    What you have to understand is that MPEG4 is an incredibly broad specification and no software can support it all. Also it’s easier to just play the file back than to be able to edit it. I see that your video is using Advanced Simple@L5 profile. It could be that Vegas doesn’t support this profile in which case you would need to convert the footage to a format that Vegas can edit. I’m just guessing here. You should probably contact Sony and see what they say about why Vegas can’t read these files but this is a common problem with MP4 files.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
