John Rofrano
September 12, 2008 at 12:23 pmThe reason I asked about the software is because most hard disk recorders and memory recorders use the FAT32 file system which limits your filesize to 4GB and causes a single recording to be broken up into several files. The software stitches these back together into one large file so that what you recorded is what you get. I was thinking that maybe this stitching would causes a re-write and thus fix any problem with the file. You might want to search the Sony site and see if there is any software you can download for your camera. Just something to try.
Of course, this may also be why the camera was being sold used on eBay. Maybe it has issues? With tape, we always record black leader and color bars at the beginning. Perhaps you should create a short black clip as the first recording so that you don’t care if the first file is always bad because it won’t be anything important. The fact that it’s always the first clip leads be to believe it might be a camera issue with writing the first clip. Still very strange. You should not be having this problem.
If you can upload a small bad clip somewhere we can download it and test it on our systems for you.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Agustin Ciccia
September 12, 2008 at 2:00 pmThanks and by the way I forgot to tell you that I tried filming 6 different shots of 30 seconds each (I paused and record again 5 times), and then, when moving them to the hard drive, Sony Vegas did not have any problem reading perfectly the first file (video and audio).
I guess the problem is with the firs FULL file (or the first partitioning of 2GB).
Camera should not be a problem, although it may certainly be, but I am afraid if I record the next long speech and do a 30 second first frame, the following would be a FULL 2GB frame that MAY show the same problem…well, I will try it, I do appreciate your help. Agustin“Verba volant, scripta manent”…
