Activity › Forums › Adobe Premiere Pro › mp4 show in preview but no video in timeline
  • mp4 show in preview but no video in timeline
    Posted by David Moor on February 10, 2020 at 1:33 am
    I’m running 13.1.5 on an iMac Pro 15.4.6. I have a bunch of .mp4’s captured and exported from Snagit that have non-standard dimensions as they are screen captures, like 1080 x 1348. Encoding is mpeg-4 base media version 2.
    The videos play just fine in preview, but when I drag them to the timeline only the audio goes, no video. I tried creating a sequence much larger than the frame size (4k) but that didn’t help. Normally premiere prompts you if the video size and timeline settings are different, but I am not getting this prompt.
    How can I edit these mp4s in Premiere?
    Ann Bens replied 6 years, 7 months ago 4 Members · 4 Replies
  • Tero Ahlfors
    February 10, 2020 at 4:49 am
    Those files are in a format that isn’t supported in Premiere. You’ll need to transcode them to a format that works or capture in a supported format.
  • David Moor
    February 10, 2020 at 10:45 am
    Thanks.
    Looking at
    https://helpx.adobe.com/premiere-pro/using/supported-file-formats.html
    it shows that mpeg 4 is supported. Is there a way of finding out what will work and what will not without having to actually import the file? In this case the file is in Baseline L3.2.
  • Todd Perchert
    February 10, 2020 at 8:07 pm
    It does sound like it may be an old 32 bit version that isn’t supported any longer. But I can’t say for sure.
    Try transcoding to another file with something like Handbrake and see what happens.
    TC
  • Ann Bens
    February 14, 2020 at 11:01 am
    Guessing you did not source patch the track:
    Adobe Certified Expert Premiere Pro CS2/CS6/CC
    Adobe Community Professional
