Activity Forums VEGAS Pro MP4 settings dependent from the PC where a project is rendered?
  • MP4 settings dependent from the PC where a project is rendered?
    Posted by Frederic Baumann on August 4, 2010 at 7:16 pm
    I am faced to a strange thing: I have Vegas Movie Studio Platinum HD 10 installed on 2 PCs.
    I am opening exactly the same .vf project on both PC, to render it in the standard MP4 default template, but the results are completely different:
    one of the MP4 files is about 10 times bigger, and much better in terms of quality than the other one.
    I used MediaInfo to view the settings of both MP4 files, you can find below the details of each.
    My question is: do you know why the settings are different, and how to change them? (the advanced settings in Vegas allow me to change the bit rate, but not settings
    like the format profile or the GOP stuff. So I guess there is another place to tune this.
    Many thanks for your help!!
    Frederic
    file 1 (the big & good quality one)
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : High@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 1 frame
    Format settings, GOP : M=1, N=13
    Muxing mode : Container profile=Baseline@3.1
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Bit rate mode : Variable
    Bit rate : 8 005 Kbps
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 25.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.347
    Language : English
    file 2 (the small and bad quality one)
    Video
    Format : AVC
    Format profile : Main@L3.1
    Format settings, ReFrames : 5 frames
    Codec ID : avc1
    Bit rate : 946 Kbps
    Height : 720 pixels
    Standard : NTSC
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.041
    Language : English
    John Rofrano replied 16 years ago 2 Members · 5 Replies
  • John Rofrano
    August 4, 2010 at 9:09 pm
    This is an unfortunate misconception. There is no “default” template. There is a template that defaults to something, but as you’ve seen, it may not default to the same thing on two different PC’s. ALWAYS select a template other than default when rendering. Select the same template on both PC’s and you will get the same results.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Frederic Baumann
    August 4, 2010 at 9:46 pm
    Thanks John.
    Then I will create my own template with the bitrate I want to have and the resolution I want to have.
    Still, I don’t understand how I managed to get 2 different “format profile” (High@L4.0 and Main@L3.1) while the option is not available in Vegas.
    Anyway I don’t know what it stands for, so I can live without knowing. But in the event you could explain this as well, I would feel happier 🙂
    Thanks again anyway, one more time I learnt something thanks to your answers!
  • John Rofrano
    August 5, 2010 at 2:55 am
    These are just different profiles for AVC. The Main profile is for SD and High is for HD. I dont’ know why Vegas picked one over the other given the same project.
    ~jr
  • Frederic Baumann
    August 5, 2010 at 9:22 pm
    Thanks John. I am actually happy – I created my own 8Mbits/sec profile and it seems to work fine.
  • John Rofrano
    August 5, 2010 at 10:40 pm
    Great. I’m glad that worked out for you.
    ~jr
