Activity Forums VEGAS Pro mp4 render quality problem
  • mp4 render quality problem
    Posted by Dave Petteruto on May 31, 2010 at 6:11 pm
    I’m rendering some high school baseball (lots of movement) video (sd) in Vegas 9.0C. What I’m noticing is that occasionally I’m getting a horizontal interference that lasts for just a quick flash. When I render the same file to avi everything looks fine.
    My render settings are: MainConcept AVC/AAC (*mp4) NTSC Square pixel (640×480) Allow source to adjust frame size=off Profile=Baseline Frame rate=30.000000 Allow source to adjust frame rate=on Pixel aspect ratio=1.0000 Number of reference frames=1 Use deblocking filter=off Variable bit rate of 6,000,000 max, 2,000,000 Average Under the “Project” tab the video rendering is set to “Best”
    I’ve tried higher settings for the bit rate and turned on two pass with no real quality change.
    FYI–this video is for posting on Youtube.
    Any thoughts or suggestions would be very much appreciated.
    Dave P.
    Santosh Nayak replied 15 years, 11 months ago 3 Members · 6 Replies
  • Dave Petteruto
    May 31, 2010 at 6:45 pm
    Side Note–After rendering to an mp2 the video was fine. So it seems that the mp4 format or the render settings are what are causing the problem.
    Dave P.
  • John Rofrano
    May 31, 2010 at 11:33 pm
    If you are posting to YouTube use one of the Internet presets under Sony AVC. These are design for sites like YouTube and require no tweaking. Just use them as is or lower the bitrate if the file size is too big.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Dave Petteruto
    June 1, 2010 at 1:31 am
    Thanks John, I’ll give it a try and see what happens.
    Dave P.
  • Dave Petteruto
    June 6, 2010 at 6:15 pm
    Hi John, I tried the Sony AVC settings as you suggested, but ended up with the same problems. I’m not sure what the deal is.
    Dave P.
  • John Rofrano
    June 7, 2010 at 2:30 am
    If it only happens with MP4 and not MPEG2 it may be a bug. You might want to contact Sony and see what they say.
    ~jr
  • Santosh Nayak
    October 27, 2010 at 10:29 pm
    hi!
    i had this problem i have sorted it out by increasing the bit rate (bps)…keep it around 6,000,000
    the file size will increase but nominally.
    try it out and let me kno if it helped 🙂
