Activity › Forums › VEGAS Pro › mp4 on fire
  • mp4 on fire
    Posted by Harijono Roebana on November 1, 2018 at 7:11 pm
    Some older mp4 files don’t play back properly in Vegas Pro 13,14 and 16. The sound is normal, but the video is way too fast.
    For example the file in MediaInfo: The Original file was an EX1 file, 720p/50, then rendered to an mp4 1920/50
    File Property settings derived from the file; all windows/vegas updates installed.
    It does play back properly in VLC or Resolve 15.
    Any thoughts on what might be wrong?
    General
    Complete name : G:\\footNOTE.mp4
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42 (mp42/isom)
    File size : 2.75 GiB
    Duration : 32 min 29 s
    Overall bit rate mode : Variable
    Overall bit rate : 12.1 Mb/s
    Encoded date : UTC 2015-01-07 04:19:29
    Tagged date : UTC 2015-01-07 04:19:29
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : Main@L4
    Format settings : CABAC / 3 Ref Frames
    Format settings, CABAC : Yes
    Format settings, RefFrames : 3 frames
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Bit rate mode : Variable
    Bit rate : 11.9 Mb/s
    Maximum bit rate : 24.0 Mb/s
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 50.000 FPS
    Original frame rate : 25.000 FPS
    Standard : NTSC
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan type, store method : Separated fields
    Scan order : Top Field First
    Bits/(Pixel*Frame) : 0.115
    Stream size : 2.70 GiB (98%)
    Language : English
    Color range : Limited
    Codec configuration box : avcC
    Audio
    Format : AAC LC
    Format/Info : Advanced Audio Codec Low Complexity
    Codec ID : mp4a-40-2
    Bit rate mode : Constant
    Bit rate : 192 kb/s
    Channel(s) : 2 channels
    Channel layout : L R
    Sampling rate : 48.0 kHz
    Frame rate : 46.875 FPS (1024 SPF)
    Compression mode : Lossy
    Stream size : 44.6 MiB (2%)
    Language : English
    Francois Pénzes replied 7 years, 10 months ago 2 Members · 1 Reply
  • Francois Pénzes
    November 2, 2018 at 3:35 am
    Hello Harijono
    First thing I noticed was that you have a different frame rate for audio compared to your video frame rate. That is most likely why the video doesn’t match your audio.
    I believe that the problem originates with the conversion that was made from the original file. Am I correct in suspecting that you used VLC to convert the file(s) ?
    You may want to start over with the conversion, try using Handbrake this time or another conversion software.
    Let us know what happens.
    Cheers !
    PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz
    Cameras: Canon XF305 + Canon XH-A1
    Blackmagic HyperDeck Studio Mini
    Vegas Pro 14, User since Vegas 3.0
    \’\’When the cutting stops, the editing begins…\’\’
