Activity Forums VEGAS Pro mp4 jitters – RAM problem?
  • mp4 jitters – RAM problem?
    Posted by Liz Margoshes on June 1, 2008 at 1:56 pm
    hi
    I am trying to use Vegas 7 with mp4’s from a new Sanyo Xacti camera.
    The files play extremely jitterily (is that a word?). Audio is fine, video is stop-and-start. Therefore I can’t see the video frame by frame in order to edit. I shot in “something” (can’t remember) x 720, so I guess that’s high def.
    I only have 505 or something useable RAM on my Toshiba laptop.
    Can you tell me how to convert to another video format using Vegas, so I can try that? (I will also try shooting in a much smaller format to see if that helps).
    Thanks.
    Steve Rhoden replied 18 years, 3 months ago 2 Members · 1 Reply
  • Steve Rhoden
    June 1, 2008 at 3:28 pm
    If you playback the video in vegas in mp4 format with a measly
    500mb of memory on a laptop…you definately will encounter this.
    the resources of your laptop is not powerfull enough to provide
    real-time playback, “especially it seems you are editing HDV, which
    requires even more resources to edit effectively in real-time.
    However your rendered projects will not be jittery..its just the limitation of your laptop during playback.
    Steve Rhoden
    TNX EFFECTS STUDIOS
