Activity Forums Adobe After Effects MP4 issue
  • Posted by Leonie Hollick on May 13, 2016 at 2:43 am
    Hello,
    I’ve been dealing with this problem for some months now, any MP4 related files glitch the frames in AECS5.5
    and I know that this is an issue with older versions aswell, the problem is, my MP4 files are over 20 min long
    and around 500 MB per file, I don’t have the space to convert/extract it to AVI or MOV, and WMV has too much quality lose. Is there any converter/extracter or something that can help me with this problem? Something that won’t lose quality and has around the same filesize, there might be an easy solution for this, but I just haven’t really found
    anything.
    Thanks in advance
    -Leonie Hollick
    Leonie Hollick replied 10 years, 3 months ago 3 Members · 3 Replies
  • Claude Rozsa
    May 13, 2016 at 5:04 am
    Hi Leonie, I use Skysoft Video converter Ultimate when I downoadl a file from youtube for instance. It has a converter included which enables you to convert to the original format the file and different settings you can change and works perfectly and is not expensive at all; check it out here
    https://www.iskysoft.com
    Hope this works for you
  • Michael Szalapski
    May 13, 2016 at 2:46 pm
    You could try using the Adobe Media Converter to transcode them into QuickTime with the Photo-JPEG codec. That’s a reasonably small file size for nearly lossless video.
    Hard drive space is relatively cheap these days, so I would look into adding some storage to your system.
    – The Great Szalam
    (The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)
  • Leonie Hollick
    May 13, 2016 at 3:40 pm
    Thank you very much for suggesting this Claude! This converter really helps!
    Much appreciated!
    -Leonie Hollick
