Activity › Forums › Apple Final Cut Pro › MP4 in FCPX and best HD frame size for SD DVD.
  • MP4 in FCPX and best HD frame size for SD DVD.
    Posted by Fredy Schwerdtner on May 30, 2012 at 9:37 pm
    Hi guys,
    I’m getting into a project which I’m having some thoughts and I would like to share to get some information.
    I will have 5 guys shooting an event with those kind of “pocket cameras” from sony, the Bloggie Touch.
    The camera can shoot HD.
    VIDEO MP4 (MPEG-4 AVC – H264) 1920X1080 (29.97p) / 1280X720 (59,94p) / 1280X720 (29.97p)
    AUDIO – MPEG-4 AAC
    I will edit in FCPX and have to author a DVD in DVDSP
    Two questions:
    1- How does FCPX works with .mp4 ?
    2- For a SD DVD, since any footage will be compressed as 720×480, should they shoot HD 1080p or 720p ??
    Thank you all !
    iMac 2.7 GHz Intel 4 Core i5
    16 GB memory
    MacBook Pro 17″
    2.5 GHz Intel Core 2 Duo
    6GB 667 MHz DDR2 SDRAM
    OWC RAID 5 with 4TB
    OS X 10.7.3
    FCPX
    Final Cut Studio “3”
    Fredy Schwerdtner replied 14 years, 3 months ago 4 Members · 10 Replies
  • 10 Replies
  • Tom Wolsky
    May 30, 2012 at 11:26 pm
    FCP doesn’t edit MPEG-4. The AVCHD media that’s in the MPEG-4 framework is rewrapped to QuickTime on import. It’s seamless.
    If you’re going to SD DVD only, you may as well shoot 720p24. It’s be easier when going from SD to HD.
    All the best,
    Tom
    “Final Cut Pro X for iMovie and Final Cut Express Users” from Focal Press
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
    Coming in 2012 “Complete Training for FCPX” from Class on Demand
  • Jeff Kirkland
    May 30, 2012 at 11:27 pm
    My general advice is shoot as high a resolution as you can, so 1080 unless there’s some technical reason not to.
    As to MP4… Even if FCPX coukd play it, it just isn’t a codec designed for editing. FCPX is built around ProRes and my advice is always to convert footage to ProRes before editing, even the other formats natively supported, as it just improves performance and saves headaches in the long run.
    Jeff Kirkland | Southern Creative Media
    video * audio * post * production
    Melbourne, Australia
  • Jeff Kirkland
    May 30, 2012 at 11:31 pm
    The advantage to shooting higher resolutions is that ‘over sampling’ by shooting at 1080 then reducing in post can help make footage from a less than great camera look better
  • Claude Lyneis
    May 31, 2012 at 4:46 am
    I am shooting 1080 H.264 format at about 24 Mb/s with a Canon XA10. As I understand it mp4 is h.264. With my new 27″ iMac I find it works well to not convert to Apple Pro Res 422. The GPU in the iMac is fast enough to play back the H.264, FCPX has no trouble editing it and it saves a huge amount of space not converting to 422. In the end with compressor I can go to whatever format is required. Hard disk are relatively cheap, but managing lots of them to use Apple Pro Res 422, seems like a nuisance.
    So I would shot in as high a resolution as possible, and the output it as needed. You might need the resolution for future use.
  • Tom Wolsky
    May 31, 2012 at 1:07 pm
    It also will produce more scaling artifacts when the image is compressed down to 480.
    All the best,
    Tom
  • Fredy Schwerdtner
    May 31, 2012 at 4:36 pm
    “Claude Lyneus: You might need the resolution for future use.”
    In this particular job, I will never see the footages again …. lol
    “Jeff Kirkland: The advantage to shooting higher resolutions is that ‘over sampling’ by shooting at 1080 then reducing in post can help make footage from a less than great camera look better”
    I totally agree.
    “Jeff Kirkland: FCPX is built around ProRes and my advice is always to convert footage to ProRes before editing, even the other formats natively supported, as it just improves performance and saves headaches in the long run.”
    Do you all believe it is true for all codecs supported by FCPX ? Including HDV ?
    16 GB memory
    MacBook Pro 17″
    OWC RAID 5 with 4TB
    OS X 10.7.3
    FCPX
  • Tom Wolsky
    May 31, 2012 at 6:32 pm
    FCP doesn’t create ProRes for HDV. If you want ProRes files you’ll have to convert the media outside of FCP.
    All the best,
    Tom
  • Fredy Schwerdtner
    June 1, 2012 at 10:49 pm
    I have been importing HDV directly into FCPX and edited without any problems. FCPX doesn’t make a Prores file out of HDV because it deals pretty well with HDV. But I was thinking if the job could be made easily and smooth if the HDV files are transcoded to Prores.
    16 GB memory
    MacBook Pro 17″
    OWC RAID 5 with 4TB
    OS X 10.7.3
    FCPX
  • Jeff Kirkland
    June 2, 2012 at 9:59 pm
    There’s certainly no need to convert something that FCPX can play natively but, and this is personal preference, I would rather just deal with one format right across my workflow.
    A typical project for me might have h264 from a dslr alongside AVCHD, XDCAM, and HDV. In my workflow, the original media gets archived and everything gets converted to ProRes whether it plays natively or not. All the conversions are done by external applications because FCPX is just way to slow if I leave it to do the conversion for me.
    The edit, for me at least, just seems to go much more smoothly if I start off with everything in the same format.
  • Fredy Schwerdtner
    June 4, 2012 at 12:32 pm
    “Jeff : All the conversions are done by external applications because FCPX is just way to slow if I leave it to do the conversion for me.”
    Hi Jeff, I totally agree with you when you talk about the velocity of FCPX. What external applications do you use for that task, I meant, to make those files a Prores file ? I have Quicktime 7 and 10, MPEG Streamclip, iSkysoft Video Converter and Voltaic.
    16 GB memory
    MacBook Pro 17″
    OWC RAID 5 with 4TB
    OS X 10.7.3
    FCPX
