Activity Forums Adobe Premiere Pro MP4 import – audio extremely shortened and sped up
  • MP4 import – audio extremely shortened and sped up
    Posted by Tim Boknecht on May 14, 2014 at 6:17 pm
    I’ve imported a long .mp4 into Premiere and have a consternating problem: The audio is significantly shorter than the video, and is subsequently sped up and therefor incomprehensible.
    Thoughts?
    Tim Boknecht
    Media Producer
    Bravo Productions
    Paddy Uglow replied 12 years, 4 months ago 3 Members · 2 Replies
  • Jon Doughtie
    May 15, 2014 at 1:52 pm
    Strangely enough, I have run into the opposite – the video flew by while the audio played normally.
    I pulled that puppy into Media Encoder, converted to another file type and moved on.
  • Paddy Uglow
    May 15, 2014 at 2:38 pm
    Is there a mismatch between the audio khz of the sequence and the clip?
    Failing that, you could try Compressor like Jon suggested, but maybe just export the audio – then you won’t be degrading the video and it’ll be quicker.
    Good luck
    Paddy, CreativeMedia.org.uk
