Activity Forums Apple Final Cut Pro Legacy MP4 conversion using VBR 2 Pass
  • MP4 conversion using VBR 2 Pass
    Posted by James Fox on June 5, 2014 at 4:52 pm
    Hi
    Have been asked to convert a video to these settings:
    Video
    Container: mp4
    Codec: h264
    1920×1080 Progressive (Deinterlaced)
    Frame rate: 25fps
    VBR 2 Pass
    Average bit rate: 2.2 mbps
    Max bit rate: 2.5 mbps
    Profile: Main
    Keyframe: every 25 frames
    Audio
    AAC
    256 kbps
    High Quality
    Is this possible through FCP or compressor? Struggling to find a setting to do VBR
    Edwin Street replied 12 years, 2 months ago 2 Members · 1 Reply
  • Edwin Street
    June 8, 2014 at 4:01 pm
    Yes use Compressor to do this. It’s fairly simple and it makes it easier that you know what you want.
    If you don’t want to buy Compressor 4 then Quicktime 7 or MPEG Streamclip will do the job.
