Activity › Forums › Compression Techniques › MP3 maximum bit rate issue
  • MP3 maximum bit rate issue
    Posted by Samrat Dutta on July 25, 2013 at 8:02 am
    I have tried to create a mp3 file with some specific parameter like maximum bitrate , duration ,sampling rate, channel. For this I have used ffmpeg Libmp3lame library with the following command ;
    ffmpeg -i OLD1.mp3 -codec:a libmp3lame -ar 32000 -ab 56k -ac 2 -q:a 1 -t 00:03:00.000 -y NEW-1.mp3
    Here we need to create a mp3 file with maxbit rate 56kbps. So I used -ab 56K but unfortunately It creates with 64K max bit rate.
    So I want to know , is there any other command to create the file with proper maxbit rate?
    and another question is what is the command in ffmpeg to get the max bit rate?
    Answer of the above two questions are relly helpful to me.
    Angelo Lorenzo replied 13 years, 2 months ago 2 Members · 1 Reply
