Activity › Forums › Apple OS X › mp3 encoding (without iTunes)
  • mp3 encoding (without iTunes)
    Posted by Gunleik Groven on November 29, 2005 at 4:18 pm
    Hi
    I know this hs been discussed before and did an advanced search before posting -;)
    Creating mp3’s from iTunes is a PITA if you need to convert content for mailing it or basicakky do anything but listen to it, as it all ends up in he dreaded iTunes library.
    Any good other solutions out there.
    I can not figure why this function has been disabled in QT as it obviously the QT engine that does the converting in iTunes “under the hood”.
    And why not use mp4?
    Compatibility.
    Gunleik
    Gunleik Groven replied 20 years, 9 months ago 1 Member · 1 Reply
  • Gunleik Groven
    December 8, 2005 at 1:03 pm
    OK.
    found the answer…
    Audacity with lame.lib does the trick for free.
    Great!
    G
