MP3 and WAV transcription file timecode question
Posted by Jeffrey Irvine on August 9, 2010 at 11:58 pmHello,
I received mp3 files for the transcription of an interview we filmed recently. The mp3 files were supposed to have time code encoded onto them, but it was not encoded onto one of the audio tracks. I’ve been assured that the time code information is stamped into the file, but I’m not sure how to read this information. Could it be in the metadata?
Similarly, I received a .Wav transcription file a while back with the same issue. The timecode was not recorded onto one of the audio tracks, but it was fed into the file. I have not found any software that can discern it.
Is there a way to get at this metadata or encoding to see the timecode?
Thank you!
-Jeff
Andrew Bateman replied 13 years, 11 months ago 9 Members · 15 Replies -
Mark Barroso
August 10, 2010 at 1:02 amYou would hear the timecode if it was there – it sounds like a sewing machine heard through a fan. It’s not just a software issue, as the words have to be sync’d with the timecode in transcription. I don’t know what hardware they use, but places like Transcript Associates in NYC can do it. Very pricey, though.
Ty Ford
August 10, 2010 at 3:16 amHello Jeffrey and welcome to the Cow Audio Forum.
I don’t know what you mean “it was not encoded on one of the audio tracks,”
Does that mean it was recorded on the other track?
You need a time code reader that will take the output from that particular track and display it.
Regards,
Ty Ford
Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
Watch Ty play guitar -
Peter Groom
August 10, 2010 at 8:41 amAs already said. if you listen to the audio tracks You WILL hear it.
(My ex boss could tell what the tc hour and minute was just be listening to it!!. He was always right, but this skill never gets a girl at a party!)
If you can hear it, you will need a TC reader to display it. This is a heardware thing i rekon.
If you cant hear it, dont bother as its not there.
MP3 doesnt support any tc option OTHER than recording it asa an ltc feed of audio (Longitudinal Time code track)
BWAV is an advanced wav file with Broadcast in its extension. This allows suitably equipped users to tc staamp the file. You will then have to have suitable software to import it and display it. Not even sure that Pro tools does this. A google for reading Bwav timecode should help.Cheers
peter
Peter
Richard Crowley
August 10, 2010 at 9:19 amBoth MP3 and WAV audio file formats support an unlimited number of internal tags. The beginning time-code is likely encoded into one of these internal tags. There are standalone utilities to read these tags. Also some applications will display the contents of these tags, and even allow editing the values.
https://en.wikipedia.org/wiki/Category:Tag_editors
Bouke Vahl
August 10, 2010 at 11:06 amIf wave contains TC, it’s probably BWF.
Besides Jeffrey’s comment, the TC MUST be stored in a Bext or Mext entry.
(Bext for Wave, Mext for Mpeg1 layer II)Mp3 is ‘not’ a BWF format.
(That does not mean that someone could have added a Bext or Mext part…)The common Mp3 style metadata is ‘sound devices’ style.
See if my Transcriber application can find the TC:https://www.videotoolshed.com/product/27/transcriber-2-dvd
If not, contact me direct and i’ll see if i can make it compatible.
Bouke
smart tools for video pros -
Ty Ford
August 10, 2010 at 11:33 amIf it isn’t on one of the audio tracks, I don’t think you’re going to hear it.
If it’s just time stamped at the beginning of the file, that’s not the same as continuous time code, it’s just a starter marker.
Regards,
Ty Ford
Ty Ford
August 10, 2010 at 11:40 amif that app doesn’t read the metadata try this one.
https://www.sounddevices.com/products/waveagent.htm
Regards,
Ty
Watch Ty play guitarSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Jeffrey Irvine
August 10, 2010 at 4:46 pmThank you for the advice, everyone. Everything you say makes perfect sense.
To clarify, I definitely do not hear the timecode on either of the audio tracks. If it is encoded somehow, it would be in the metadata as Ty and Bouke say.
Unfortunately, I’ve tried a couple of tag readers and Bouke’s Transcriber software, and nothing has been able to detect timecode. It’s certainly possible that it simply was not encoded after all, but I am still exploring other options.
I suppose once the footage is loaded, we could export a QT from Avid with the timecode embedded and use that for transcription (assuming Avid can still export QTs with embedded timecode — I would hope to avoid the render time of using BITC). It would be ideal to have it transcribed sooner, however. I’ll let you know if I have any luck.
Bouke Vahl
August 11, 2010 at 8:31 amJeffrey,
Do drop me a line and send me an example file.
(I’m a TC geek, if it is there, and it is in a format i don’t know yet, i want to see it…)Can’t be that hard, there are only a few places where it can live.
Bouke
Matt Mayer
August 13, 2010 at 11:36 pmJeffrey,
If the file came from a Sound Devices machine, the TC metadata would be in the ID3 tags and easily viewable in any software that will show you the standard MP3 tags – they even will show in Windows File Explorer.
If the tags are there, BWF Widget will read the MP3 tags and show you running timecode while the files are playing. N.B. – BWF Widget is PC only.
—Matt
—Matt
