Activity › Forums › Compression Techniques › MP2 on YouTube
  • MP2 on YouTube
    Posted by Lincoln Athas on September 1, 2009 at 9:12 pm
    YouTube says that it accepts the MPEG2 format, and so I uploaded an MPEG2 video file of my movie and indeed it looked great, much better than MPEG4 or H264. However, there was no audio, as the mp2 video file is independent of the audio file. I then found no way to swap the audio in.
    Does anyone have a solution to this? Can I upload the audio file by itself and then combine the two?
    Thanks a bunch
    Chris Blair replied 17 years ago 3 Members · 5 Replies
  • Daniel Low
    September 1, 2009 at 9:22 pm
    [Lincoln Athas] “Can I upload the audio file by itself and then combine the two?”
    No, you need to have them muxed before upload.
    “There’s no chance that the iPhone is going to get any significant market share. No chance.”
    Steve Ballmer To USA Today
  • Lincoln Athas
    September 1, 2009 at 11:31 pm
    Thanks…can you recommend a good muxer, to mux an m2v file and aiff file, on a mac?
    I tried ffmpegX and it muxed a few seconds of the clip but then “failed”
    I also tried going through DVD Studio Pro, and using the VOB file to make an mpg file, but to no avail.
    Thanks for the help,
    Lincoln
  • Lincoln Athas
    September 2, 2009 at 1:55 am
    Problem Solved.
    I downloaded MPEG Streamclip for Mac OS here: https://www.squared5.com/
    Had to make sure the m2v and aiff files have the exact same name, then opened the MPEG Streamclip app and just opened the m2v file…it brings in the aiff file with it automatically. Then chose File/Convert to MPEG with MP2 audio
    In case anyone is interested…
  • Daniel Low
    September 2, 2009 at 6:39 am
    Exactly the application I was going to suggest.
    In future, make your MPEG files as program streams if you are going to upload them to Youtube
  • Chris Blair
    September 3, 2009 at 2:38 am
    If you’re on Windows, TMPGEnc 2.5 is a freeware MPG encoding tool that has a muxer app built in that’s also very good. It can demux, mux, join, and split files and works really great.
    https://tmpgenc.pegasys-inc.com/en/download/tpfree.html
    Chris Blair
    Magnetic Image, Inc.
    Evansville, IN
    http://www.videomi.com
