Activity › Forums › Adobe Photoshop › Movng Transform Handles
  • Movng Transform Handles
    Posted by John Phillips on September 19, 2011 at 3:03 pm
    Hi all,
    I have a project where I’m trying to exactly align up the corners of four very large maps so that I can build a single map image out of them. Each one is about 40″ x 30″ in size. Since they weren’t scanned exactly the same, I’m trying to transform skew the corners into the same position using one map as a reference. From there I can then be assured that they are all the same size and can proceed to build the single image out of them.
    What I’m wondering is if there’s a way when I’m zoomed into the corner of the maps if I can move the transform handles so I can use them while zoomed in. Right now when I zoom in the handles go outside the working area of the window and I cannot access them.
    Any suggestions?
    Ben G unguren replied 15 years ago 2 Members · 3 Replies
  • Ben G unguren
    September 22, 2011 at 6:47 pm
    You can use numeric transformations at the top of your PS window….
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • John Phillips
    September 22, 2011 at 7:49 pm
    Hi there,
    I tried doing the transforms numerically but unless I can grab one of the four corner handles, the numeric x/y value moves the entire layer. Is there a way to specify the numeric value controls a specific corner handle?
    John
  • Ben G unguren
    September 23, 2011 at 1:25 pm
    I don’t think you are able to do individual corners numerically (though I agree it would be useful sometimes!)
    Ben Unguren
