Activity Forums Adobe Premiere Pro Moving/copying clips from timeline into a bin
  • Moving/copying clips from timeline into a bin
    Posted by Robert Withers on August 17, 2015 at 1:29 am
    I’m trimming a timeline in PP CC 7.2.2 and would like to place the cut/deleted shots in an “Outs” bin. Can’t make this happen.
    When I drag a clip from timeline into a bin, it shows up in the bin as black.
    I can “copy” in the timeline but there’s no “paste” option in the bin. I can drag the clips into another timeline but not into a bin.
    I seem to remember doing this all the time in FCP7.
    This timeline was heavily processed–deinterlaced and uprezzed . . .
    Any ideas? Many thanks.
    Robert Withers
    Independent/personal/avant-garde cinema, New York City
    Robert Withers replied 11 years, 1 month ago 2 Members · 4 Replies
  • Alex Udell
    August 17, 2015 at 1:27 pm
    you should be able to “Subclip” to the bin.
    CMD U
    Alex Udell
    Editing, Motion Graphics, and Visual FX
  • Robert Withers
    August 17, 2015 at 4:30 pm
    Thank you, Alex, that’s a helpful tool.
    Here’s how I’ve found it works. . .
    Select a clip in the timeline with in/out, make subclip.
    Select a clip in the source monitor and make subclip.
    On OK, it automatically makes a subclip in the main project folder, which I can them move to an “Outs” bin.
    I’m not finding a way to save the subclip with my in/out points marked.
    If I unselect “Restrict Times to Boundaries” it saves the whole clip with no record of my in/out points. I’m not able to add markers to the source clip or the timeline that are saved with the subclip.
    If I do select “Restrict Times” it only saves the part of the clip between in/out.
    Maybe I’m missing something, but this is indeed a way to save timeline clips to a bin, if not with the marker information.
    Robert Withers
  • Alex Udell
    August 17, 2015 at 4:47 pm
    hmmm….
    what version of PPro are you on?
    when I drag a clip from the timeline to the project panel…
    (no subclipping)
    it remembers my in/out as set on the timeline….
    i’m running 8.1
    Alex Udell
  • Robert Withers
    August 17, 2015 at 5:22 pm
    Thanks, Alex, I’m running 7.2.2.
    And now I see the drag method was working all along—the first shots I dragged had long slow fade-ins from black and so showed up black. My dumbo!
    I’ve learned some other things along the way, though, about duplicating in-progress sequences for backup reference instead of the whole project file.
    And your tips about subclips.
    Thanks again for your responses!
    Robert Withers
