Activity Forums Adobe After Effects Moving Views Around
  • Moving Views Around
    Posted by Jim Ives on June 14, 2008 at 1:09 am
    Ok here’s another noobish question. I keep checking my work from different angles to see how it looks. I’m using the orbit camera to move around and view from different angles. Every time I move it though it leaves a key frame. Is there a way to swing around and look from different angles without using the orbit camera or without it leaving a key frame? Im finding I have to keep going back and deleting key camera frames it’s leaving that I dont’ want in the compotion.
    Jim
    Jim Ives replied 18 years, 3 months ago 2 Members · 6 Replies
  • Joey Foreman
    June 14, 2008 at 1:56 am
    Use those tools in one of the Custom Views. Click on the Active Camera button at the bottom of the Comp window to reveal them.
    Joey Foreman
    Editor/Animator
    Nowhere Productions, Athens, GA
  • Jim Ives
    June 14, 2008 at 4:25 am
    Ok. I think I’m following that. So if I just want to spin around and zoom in and out and what not to view my work i can drop down to say Custom View 1 and do it there and it will not leave key frames for my active camera. Then when I want to get back to adding new camera angles and zooms i can just switch back up to Active Camera to set the key frames I DO want.
    Jim
  • Joey Foreman
    June 14, 2008 at 5:17 am
    You got it.
    Joey Foreman
    Editor/Animator
  • Jim Ives
    June 14, 2008 at 6:24 am
    Wow it’s complicated and I’m just scratching the surface here. Thanks!
    Jim
  • Joey Foreman
    June 14, 2008 at 3:57 pm
    Think of the camera tools as a way to drive your Active Camera when in that view. In the custom view they control a sort of all seeing eye, separate from the camera. You can see your camera in custom views, and move it around with axis handles just like any other object/layer.
    Joey Foreman
    Editor/Animator
  • Jim Ives
    June 14, 2008 at 7:11 pm
    I saw that that you CAN infact move the camera around when in one of the other views. I guess it will take me a while just to get past the basics! 🙁
    Jim
