Activity Forums Apple Final Cut Pro Legacy Moving up to HD
  • Moving up to HD
    Posted by Bruce Breidbart on January 12, 2011 at 1:44 pm
    I’m running a MacPro 2 x 2.66 dual core Intel, w 8gigs of ram & FCS 2 . It’s time
    for a new HD camcorder . I’ve read a lot of good reviews about Panasonics TM700
    but have some questions that this forum might be able to answer. The TM700
    can record full HD 1080/60P, very impressive untill you want to edit in FCP6.
    I’ve read that someone has used “ClipWrap” to rewrap to a quicktime file, I suppose FCP would like to see a Pro Res file.Does anyone have a good experience with ClipWrap ?
    I’ve read this camera records 1080/24P , but in the small fine
    print it says that 24P is converted & recorded as 60i , I’m a little confused, what gives ?
    My last question, I need to do a little more research but this camera records to SD/SDHC/SDXC memory cards, but I don’t see what class card they are looking for, no sence paying more if it’s not needed ?
    I know it’s a lot to ask,
    thanls in advance
    Bruce Breidbart replied 15 years, 8 months ago 3 Members · 6 Replies
  • Craig Alan
    January 12, 2011 at 2:09 pm
    i think you should be good with class 6. look for deals. prices coming down. go with major brands. read reviews. some have more failure rates than others. sandisks are good.
    OSX 10.5.8; MacBookPro4,1 Intel Core 2 Duo 2.5 GHz
    ; Camcorders: Sony Z7U, Canon HV30/40, Sony vx2000/PD170; FCP certified; write professionally for a variety of media; teach video production in L.A.
  • Cade Muhlig
    January 12, 2011 at 4:17 pm
    Transcend Class 6 works for me. This camera has a lot of nice features. There are few problems I have have with it though. Firstly, I really don’t like the 60p. The motion is a lot different than what you are used to. It kinda makes me sick. You feel like you can pan much faster because there us less blur. But when you watch it on tv it looks very unnatural. I’ve completely abandoned 60p. It will save you in post as well.
    The second thing is the shot stabilizer. It’s very herky-jerky and again unnatural. A lot of harsh corrections. When you pan and come to a stop the camera will keep panning a little, then jerk back. And you can’t turn it off.
    I would probably go with something a little more proven if I had to do it again. But at least I only use it when I can’t use the big camera!
  • Cade Muhlig
    January 12, 2011 at 4:29 pm
    And I never seen anything about 24p unfortunately.
  • Bruce Breidbart
    January 12, 2011 at 6:48 pm
    ” In either case, it’s essential to remove the pulldown from 24p 1080 footage and get it to a 23.976 (aka 23.98) frame rate”
    Could you please explain why ?
    thanks
  • Bruce Breidbart
    January 12, 2011 at 6:53 pm
    heading there right now.
    thanks
  • Bruce Breidbart
    January 12, 2011 at 7:03 pm
    thanks,
    I’m learning about read & write speeds, but right now they are just numbers to me.
    I’ve got nothing to compair what a 20mb/s cards speed really means.
