Activity Forums Adobe After Effects Expressions Moving the last keyframe in time using expressiosn
  • Moving the last keyframe in time using expressiosn
    Posted by Ivan de Wolf on July 19, 2022 at 1:49 pm
    Hello!
    I have a pair of keyframes for animating a parameter. I would like to move the second keyframe across time, so that the animation can be shortened or lengthened using a simple slider control. I found some solutions online, but they don’t fully seem to work with isolating the time movement of just one keyframe.
    Any ideas??
    Ivan de Wolf replied 4 years, 1 month ago 4 Members · 4 Replies
  • Adam Greenberg
    July 19, 2022 at 1:55 pm
    this has been discussed before, here is a link until someone potentially rings in with a more concise answer,
    https://community.adobe.com/t5/after-effects-discussions/link-a-keyframe-to-slider-control-without-affecting-other-keyframes/td-p/9887407
  • Dan Ebberts
    July 19, 2022 at 2:00 pm
    You can’t really move keyframes with expressions, but you can simulate it with something like this (assumes there are only 2 keyframes):
    t1 = key(1).time;
    t2 = key(2).time;
    tNew = effect("Slider Control")("Slider");
    t = linear(time,t1,tNew,t1,t2);
    valueAtTime(t)
  • Filip Vandueren
    July 19, 2022 at 2:10 pm
    If you want to keep the easing you already have set up between your keyframes and don’t want it to default to the linear() or ease() functions:
    (this example has 3 keyframes, and a slider controls how long the animation should last after key#2, disregarding the actual timing of keyframe#3
    time_2 = key(2).time;
    time_3 = time_2 + Math.max(0,effect("Slider Control")("Slider").value);
    if (time < time_2) {
    value;
    } else {
    t=linear(time,time_2, time_3, time_2, key(3).time);
    valueAtTime(t);
  • Ivan de Wolf
    July 20, 2022 at 12:21 pm
    WOW thank you everyone for the fast response! It works perfectly! <3
