Activity › Forums › Maxon Cinema 4D › Moving texture problem
  • Moving texture problem
    Posted by Michael Clark on June 18, 2014 at 1:44 am
    Hello-
    having some issues with animating a texture.
    I have a text object that I am trying to animate a tall image of multiple textures and slide it down so that every few seconds it slides to the next image in the pre made jpg file.
    WHen i animate the V offset key frame at frame 30, and same value at frame 50, the value changes and almost bounces.
    Is there a setting i am missing?
    Brian Jones replied 12 years, 3 months ago 2 Members · 1 Reply
  • Brian Jones
    June 18, 2014 at 2:21 am
    sounds like it’s probably the values between the keyframes. Flatten out the F-Curve between the keyframes in the F-Curve editor probably
