Activity › Forums › Media 100 › Moving synced audio in 7.5
  • Moving synced audio in 7.5
    Posted by Andrew Mehta on February 6, 2007 at 2:38 pm
    Hi…I’ve a lot of synced audio in tracks A1/A2, I want moved to A7/A8..is there some quick way to do it, without losing sync with video, or re-establishing sync with video afterwards? Atm, I assume I could set my range, select all in range in track, unsync…then deselect, so as to unselect the previously synced video, then select all in range in track A1, hold down shift, select all in range in track A2….drag both A1 and A2 down to A7/A8…but then how to sync it all up with the individual video clips again, without having to seperately click each split clip and sync it…that would take ages.
    Is there a way to sync all clips across a range, or something?
    Or is 7.5 too old a version to do this quickly?
    If there’s a little trick to it, let us know. ^_^ Ta.
    Andrew Mehta replied 19 years, 7 months ago 2 Members · 4 Replies
  • Floh Peters
    February 6, 2007 at 2:54 pm
    Select your audio clips, press “CTRL” and “ALT” and drag the clips down.
  • Andrew Mehta
    February 6, 2007 at 2:56 pm
    Hurrah! ^_^ Will try it out immediately.
    Had discovered the usefulness of holding in CTRL recently, but never used ALT as well before – so cheers. =)
  • Floh Peters
    February 6, 2007 at 3:00 pm
    CTRL-ALT is always for synced (stereo) audio. Very useful 🙂
  • Andrew Mehta
    February 6, 2007 at 3:34 pm
    Indeed, and it has worked a treat. 😉
    Ta Floh.
