Activity Forums Adobe After Effects Moving start of layer to the current time marker
  • Moving start of layer to the current time marker
    Posted by Alex Volkov on August 23, 2010 at 8:23 am
    Hi
    Is it possible with a shortcut to move the “layer-square”, so it begins at, where the current time indicator is?
    Like Alt+Home/End to push the “layer-square” to the start/end of the timeline, but only with the current timeline cursor instead?
    Best Regards
    Alex Volkov replied 16 years ago 3 Members · 3 Replies
  • John Cuevas
    August 23, 2010 at 1:15 pm
    Use the “[” to move the head of the clip to the CTI, or “]” to move the tail of the clip to the CTI.
    Johnny Cuevas, Editor
    http://www.thinkck.com
  • Todd Kopriva
    August 23, 2010 at 3:24 pm
    Alex, all such shortcuts are here.
    Here’s a search using the words from your subject line that returns these shortcuts.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Alex Volkov
    August 23, 2010 at 4:09 pm
    Great, thanks. I obviously changed that key. It’s name is “TimeSetIn”/”TimeSetOut” under the “CCompTime” category.
    Edit: To Todd – I know that list (thanks though). But as I said; I’ve changed it, so it can be hard to find it, once I did. And the list you linked to, does not correspond (in order) to the list of the TXT file (where you manually change shortcuts), so it took me some time to find it.
