Activity › Forums › Maxon Cinema 4D › Moving rotation axis
  • Moving rotation axis
    Posted by Brett Thayer on September 24, 2008 at 7:47 pm
    I’m animating a model that will need to rotate along 2 different points…imagine a screwdriver prying closer to the handle..then later in the animation prying closer to the tip. How do I move the object center point without messing up the entire animation?
    Adam Trachtenberg replied 18 years ago 2 Members · 1 Reply
  • Adam Trachtenberg
    September 24, 2008 at 8:49 pm
    The easiest way to deal with it is to nest the object inside of two nulls: one at the tip and one at the base. Then animate the nulls instead of the object. So the heirarchy could be:
    TipNull
    —-BaseNull
    ———Obect
