Activity Forums Adobe After Effects Moving reflection
  • Roland R. kahlenberg
    September 4, 2007 at 8:55 am
    Parenting is something that should also work for your needs. And no scripting involved. I’ve not taken a hard look at Andrew’s tutorial but I did something similar for one of my products a couple of years ago. The trick is to Parent the reflection layer’s matte layer (Ramp) to the reflection. It will also help that the matte layer (created with Ramp) is large enough for your moves without being cutoff from the Comp panel.
    Cheers
    Roland Kahlenberg
    https://www.broadcastGEMs.com – Adobe After Effects project files
    https://www.myspace.com/rorkrgbspace
