Activity › Forums › Storage & Archiving › Moving RAID enclosure from one mac to another
  • Moving RAID enclosure from one mac to another
    Posted by John Davidson on December 8, 2010 at 12:05 am
    Hey Bob,
    A very simple/dumb question. If I have the same RAID controller card on two macs with all the same software installed, can I unplug my mini-sas RAID5 array from one and into the other as if it were a regular hard drive? Not sure if the controller card for my RR4322 has data-specific information on it to control a specific enclosure, or if it merely ‘reads’ the information on whatever drive is inserted.
    Jon Schilling replied 15 years, 9 months ago 3 Members · 4 Replies
  • Bob Zelin
    December 8, 2010 at 2:37 am
    sometimes yes, sometimes no. I used to assume that the answer was always YES. You had two identical RAID host cards, just move your drive array. But I learned the hard way that sometimes, if you have TWO DIFFERENT DRIVER VERSIONS, or two different firmware flash versions with the same card, the media will not be seen by the second computer. When I called to complain about this, I was told “load the older version of driver on machine # 2, and you will be able to see the media”.
    DONT THESE COMPANIES CHECK FOR BACKWARD COMPATIBILITY !!!!!!
    well now I know the answer to this – No, they don’t.
    Bob Zelin
  • Jon Schilling
    December 8, 2010 at 7:18 pm
    John,
    In addition to Bob’s post, it could go either way, I’d check with your RAID Card manufacturer to see if what you’re wanting to do would work…
    Jon Schilling
    RAIDON-USA Technology
    STARDOM Storage by RAIDON
    15356 East Valley Blvd., Suite B
    City of Industry, CA 91746
    Tel: 626-333-7888
    http://www.stardom-usa.com
  • John Davidson
    December 9, 2010 at 1:48 am
    Thanks guys! Will do. The machines will be identical so that should help.
  • Jon Schilling
    December 9, 2010 at 5:51 pm
    A couple questions the RAID card people will want to know.
    Same OS on both machines?
    Same hdd’s in your external storage with the same firmware on both machines?
    Same firmware on both RAID cards?
    If yes to all, sounds like you’re on the right track.
    Jon
