Activity › Forums › Apple Final Cut Pro Legacy › Moving project from FCP 6 to FCP 7
  • Moving project from FCP 6 to FCP 7
    Posted by Smith Glover on January 3, 2012 at 1:23 am
    I am currently running FCP 6.0.6. I have a client that needs a project done in FCP 7. I can’t currently upgrade my machine, for various reasons. My question is- if I edit in FCP 6, and then do a final pass in FCP 7 on someone else’s machine (saving it as a FCP 7 project), will this cause any issues? In other words, does doing a project in FCP 6 and then saving it in FCP 7 create the same project as if it were done in FCP 7 the whole time? I want to make sure that I give my client what he wants.
    Barbara Keating replied 14 years, 6 months ago 4 Members · 4 Replies
  • Shane Ross
    January 3, 2012 at 2:09 am
    Going from 6 to 7 is easy. You won’t even notice a thing.
    Going from 7 to 6…that’s the tricky part.
    Shane
    Little Frog Post
  • Steve Eisen
    January 3, 2012 at 2:12 am
    You can natively open an FCP 6 project in FCP 7. This will not cause any issues. The only way to open the FCP 7 project back in FCP 6 is by using XML export.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Smith Glover
    January 3, 2012 at 2:17 am
    Thanks to both of you- that’s what I was hoping.
  • Barbara Keating
    March 20, 2012 at 4:58 pm
    Hi guys, I had a pal call today saying they can’t play their sequence having upgraded from FCP6 to 7.
    Instead of the sequence clips being blue, they are white and won’t play. Audio is OK.
    The footage was originated on a JVC 111 and is MPEG 2 and was being edited natively in FCP6.
    Snow Leopard10.3.6
    Apparently it takes hours to open, and it seems to be rendering all the time.
    Any clues ?
