Moving project form Adobe Premiere CC to Final Cut Pro X (Issues with RED Footage)
I have received a project as a XML file that was originally created in Adobe Premiere CC 2015.3 Release.
All the footage is also available I do understand that all the Dynamic Linked After Effects projects need to ether be rendered out or redo them in Final Cut Pro X.But for some reason, some of the REDRaw are being displayed as Gaps or Compound Clips which are then represents with Gaps.
One of the error message from the Translation Results is:
Translation issue:
Effect on Clip not translated.What would the steps be to get the clips to show up?
