Activity Forums VEGAS Pro Moving part of the screen (I’m lacking a good way to call this)
  • Moving part of the screen (I’m lacking a good way to call this)
    Posted by Geert Feenstra on May 8, 2015 at 10:45 pm
    What I’d like to do is move part of the screen over to somewhere else on the screen.
    Lets say I have my video devided in four squares Topleft TopRight BottomLeft BottomRight
    Now I’d want to move BottomLeft over to BottomRight, whilest keeping its contents intact (meaning, having it still moving).
    Its obviously going to sit ontop of BottomRight so that will no longer be in view and BottomLeft will leave a gaping hole.
    As for an example (ditch the four squares mindset) you’d have a ammo counter in a shooting game and you wouldn’t like the position of it or would make it want to be easier seen by the user (bigger). Can i cut out that ammo counter, move it along the screen and position it somewhere else, say the middle. (and im sure i can scale it up myself then, atleast i hope so)
    I hope this makes sense to someone.
    I’ve tried searching for something like this but im just not searching with the right query.
    Everytime results are something like; cutting and pasting on the timeline.
    I’m probably not making a lot of sense but I hope that someone is able to understand this and help me out with it.
    Just to clarify none of the two things posted above are what I want (in this case), its just to know for general use .As I’ve found that i wanted to use this many times, but have never been able to do it.
    -Geert
    Geert Feenstra replied 11 years, 4 months ago 4 Members · 6 Replies
  • John Rofrano
    May 8, 2015 at 11:58 pm
    You probably want to use Track Motion to do this. You can make the frame smaller and move it anywhere you want. It affects the entire track so place whatever it is you want to move on it’s own track. If you need to crop it out instead of resize you can use Pan/Crop to do this. You can also place Track Motion in 3D mode to really move things around in 3D space (e.g., rotate on X,Y,Z axis). In fact, you can use 3D Track Motion to create cube with 6 tracks. It’s quite powerful.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Geert Feenstra
    May 9, 2015 at 12:18 am
    Thanks a lot man!
    Tried it out for a bit and this indeed does seem to be what i was looking for!
    All the extra features are a bonus. even so, good to know.
    -geert
  • John Rofrano
    May 9, 2015 at 1:34 am
    You’re welcome. Glad I could help.
    ~jr
  • Graham Bernard
    May 9, 2015 at 12:53 pm
    Ooops .. wrong tread . . .
    G
  • Bob Peterson
    May 9, 2015 at 2:00 pm
    John described how to move the screens. You can also do the ammo counter, if I understand what you mean by that, by rotoscoping with a mask. That can work in theory, but it would be an enormous amount of work. Things like After Effects have tools to make rotoscoping a lot easier.
  • Geert Feenstra
    May 9, 2015 at 2:05 pm
    Thanks for the info, as said it’s more of a knowhow thing than something that I actualy want to implement right now so I haven’t tried it in great detail.
    But im fairly certain the previous suggestion will work. I will look into your method aswell, since it has gathered my interest.
    -Geert
