Activity Forums Adobe After Effects moving paint brush
  • moving paint brush
    Posted by Dale Paquette on October 22, 2010 at 5:39 pm
    Perhaps someone knows how to do this…I want to motion track a moving object in a clip and then apply the track data to a null object. NEXT, I want to link a paint brush to the null object so that it paints a continuous stroke that matches the movement of the tracked point. I have managed to create a single frame paint “dot” and then link the dot’s position to the null – it moves along fine but doesn’t paint a continuous line. Some how I need to account for a regular paint stroke requiring the mouse button be held down. Thanks
    Dale Paquette replied 15 years, 11 months ago 3 Members · 3 Replies
  • Dane Cannon
    October 22, 2010 at 5:56 pm
    Use a particle generator. Make the emitter be the point. Turn the birth rate up high so it looks like a continous line. Modify the life time to the length that you need it to be. Turn off gravity and maybe mess around with the other physics.
  • Kevin Camp
    October 22, 2010 at 5:57 pm
    you can set the paint brush settings to ‘write-on’, but i’m not sure you could link it to your tracking null.
    you could try the write-on effect, enable expressions for the brush position property and use the expression pickwhip and drag it to the null’s position property to link them together. then the write-on brush should follow your track.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Dale Paquette
    October 22, 2010 at 8:57 pm
    Thanks, I tried it and it worked. Dale
