Activity Forums Adobe Premiere Pro Moving objecs
  • Moving objecs
    Posted by May Kindred-boothby on May 16, 2017 at 3:32 pm
    Hello,
    Does anyone know of a plug-in to allow more control over the movement of objects in premier?
    I’m putting together a frame by frame animation, and i need to be able to edit the sequence of the frames as i go so don’t want to use after effects (where it seems you can only import a seqeunce of images, that you cant really then edit them?) but i also want to move it. I’ve nested them and am using the position and rotation key frames, but i need more control (akin to after effects)
    Any suggestions?
    Brad Coulter replied 9 years, 4 months ago 2 Members · 1 Reply
  • Brad Coulter
    May 17, 2017 at 12:54 am
    Sounds like a job for Dynamic Link. 🙂
