Activity Forums Adobe Premiere Pro moving multiple sequence markers
  • moving multiple sequence markers
    Posted by Marc Nibor on July 28, 2015 at 1:38 pm
    is there a way to move all sequence markers at once?
    I had to insert 15 seconds at the beginning of my sequence, so now all the markers are off by that amount of time.
    I was wondering if it is possible to move all markers at once instead of doing it individually
    Kazu Takeda replied 6 years, 6 months ago 6 Members · 6 Replies
  • Alex Udell
    July 28, 2015 at 1:51 pm
    hi
    from: https://helpx.adobe.com/premiere-pro/using/whats-new-7-1.html
    Ripple Sequence Markers
    In earlier versions of Premiere Pro, sequence markers were fixed on your timeline. When you deleted a part of a clip and closed the gap using ripple-delete, or inserted a clip using insert-edit, your markers wouldn’t move with the clip.
    Premiere Pro now lets you use Ripple Sequence Markers to let your markers ripple upstream or downstream when cutting or trimming in your timeline. For example, after an insert-edit, any sequence markers after the insertion point ripple downstream. Similarly, after a ripple-delete, any sequence markers after the last deleted frame ripple upstream.
    To turn on or off Ripple Sequence Markers, select Marker > Ripple Sequence Markers.
    Alex Udell
    Editing, Motion Graphics, and Visual FX
  • Marc Nibor
    July 28, 2015 at 2:44 pm
    Thanks Alex
    a very helpful answer from you – as usual ; )
    That last line was the info I was missing!
  • Navin Kulshreshtha
    July 27, 2017 at 5:17 pm
    Hi Alex, thanks for the information! This is a great feature in Premiere Pro that I was not aware of. It is a great time saver. Navin
  • Vasia Markides
    December 20, 2017 at 9:40 pm
    This is extremely helpful, thank you.
    To add on to this question — can you copy markers along with clips when copy-pasting clips from one sequence to another? In other words, can you drag around the markers onto another timeline and/or can you permanently attach it to a clip?
  • Mateo Hinojosa
    September 10, 2018 at 5:04 pm
    Thanks for those tips on ripple editing. I have found the Ripple Edit tool to be very useful to move scenes and clips around on a timeline and maintain associated markers in place in relation to clips/scenes.
    I also would love to know if there are other ways to copy-paste markers along with specific clips or whole scenes.
    Preferably, I would love to be able to move markers with:
    – some kind of special “Copy With Markers”, to be able to copy a clip or whole scene from one section of a timeline to another (or to another timeline).
    – some kind of dedicated “Selection With Markers” tool.
    I am happy to submit a Feature Request, but want to make sure first that similar options do not already exist.
  • Kazu Takeda
    February 26, 2020 at 5:46 pm
    This is incredible. Thank you so much!
