Activity Forums Adobe After Effects Moving Multiple Mask Points
  • Moving Multiple Mask Points
    Posted by Max Jackson on February 16, 2010 at 5:00 am
    While masking or rotoscoping, one can click, then Shift click each additional point to move multiple points.
    However at times I’ve been able to click, then Shift drag a box around the points I want which is a lot easier.
    Has anybody run into this? And what am I doing that sometimes it works and sometimes it doesn’t?
    Max Jackson replied 16 years, 6 months ago 2 Members · 2 Replies
  • Todd Kopriva
    February 16, 2010 at 9:01 am
    See “Select masks, segments, and vertices”.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Max Jackson
    February 17, 2010 at 2:53 am
    Hey Todd,
    Yeah, I really search those sites. I know this stuff should typically be out there before asking the same redundant question. It’s just that I could be doing one small thing and that’s why it doesn’t work.
    Like I figured this one out. The reason it was only working sometimes, was because I think before I wasn’t selecting a point first. I could’ve sworn that’s what I did before trying to drag across more points.
    Anyway, hopefully that stupid mistake on my part was the key. I love it when I’m wrong that way. I can get back to asking real questions.
    Thanks, 🙂
    -soupking
